Enable/Disable mobile connect
Answered Question
Apr 5th, 2009
In the configuration guide it states that the mobility softkey when not in a call can be used to disable or enable the mobile connect feature.
However, this softkey is not working. All the other things are working fine. The user has to enable/disable this feature using the user options web page.
When you press the mobility softkey, it just says: "MobileConnectOn".
I have read several things on this forum, but nobody came up with a solution. I don't want a workarround, I want a working softkey as described in the config guides.
Best Regards,
Wouter Eelen
Correct Answer by gogasca about 7 years 9 months ago
which version of cucm u have?
Overall Rating: 3.5 (2 ratings)
jconi Mon, 04/06/2009 - 00:17
HI Wouter,
It should work only in CUCM v7
kr
jp
e.silva_2 Tue, 06/16/2009 - 15:54
I have the same issue in version 6.1.x, i just tested in version 7.x and works fine.
ayman_sheta Mon, 06/29/2009 - 22:48
I have the same Issue also on CUCM 6.1(3)
but I also it work fine on CUCM 7.0(2)
So Please if anyone come to idea Please Post it
amir_mongy Tue, 06/30/2009 - 02:43
I have the same problem in 6.1(3)
but its working in 7.0 and 7.1
Any ideas?
