Failed to http firewall (pdm) page
Apr 5th, 2009
Dear sir,
We have an existing 5 ip address that able to http into the pdm page. We try to add in 4 new ip address for http into the pdm page as well. Hereby we applies below steps 1 & 2 to achieve the objective.We try to use 1-4 pc that used the new ip address ,, & to http into the pdm but we not able to login as shown in attachment "can't login.jpg" and prompt up error message as shown below --Java Error--.
Please advise any idea to solve this issue. Thank you very much and appreciation.
Step 1
To identify the IP addresses from which the FWSM accepts HTTPS connections, enter the following command for each address or subnet:
hostname(config)# http source_IP_address mask source_interface
Step 2
To enable the HTTPS server, enter the following command:
hostname(config)# http server enable
For example, to enable the HTTPS server and let a host on the inside interface with an address of access ASDM, enter the following commands:
hostname(config)# http inside
To allow all users on the network to access ASDM on the inside interface, enter the following command:
--Java Error--
Java Plug-in 1.6.0_12
Using JRE version 1.6.0_12 Java HotSpot(TM) Client VM
User home directory = C:\Users\user1
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class not found.
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$ Source)
at Source)
Caused by: open HTTP connection failed:
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$ Source)
at Method)
... 7 more
Exception: java.lang.ClassNotFoundException:
Overall Rating: 2 (1 ratings)
pradeepde Sat, 04/11/2009 - 08:42
PIX Device Manager (PDM) versions 3.0(1) , 3.0(2), 4.0(1), and 4.1(1), and IDS Device Manager (IDM) version 5.0(1), are incompatible with Java Plug-in versions 1.4.2_08 and 1.5.0_02 or later. If these Java Plug-ins are used in conjunction with the impacted PDM or IDM releases, the application will not load.
The latest maintenance releases PDM 3.0(3) and later, PDM 4.1(2) and later, and IDM 5.0(2) and later resolve this issue.
fungchai2020 Sun, 04/12/2009 - 14:20
Hi netpro/pradeepde,
Please see on the attachment "can't login.jpg" on the first post . We are running on pdm 3.0(3) with try to login with java client version 1.6 .
Please help and appreciation.
mdombek_biz Fri, 04/17/2009 - 08:36
Hi fungchai2020,
please check if your problem still occures if you downgrade to some Java Version 1.6_6. I've often noticed that Cisco has some problems with Java versions later in ASDM/ PDM etc.
