cisco 7206VXR router keep booting on older IOS
Answered Question
Apr 6th, 2009
Hi.
I wanted to boot a cisco 7206VXR router on IOS c7200-is-mz.124-18e.bin.
However the router keep booting on the older IOS c7200-is-mz.122-15.B.bin.
The configuration/status before I reload:
1. Configuration register is 0x2102
2. gw-btvoice-sto2#sh run | in boot sys
boot system flash disk2:c7200-is-mz.124-18e.bin
3. gw-btvoice-sto2#sh bootvar
BOOT variable = disk2:c7200-is-mz.124-18e.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
4. gw-btvoice-sto2#sh disk2:
-#- --length-- -----date/time------ path
1 16371056 Apr 05 2009 17:51:12 c7200-is-mz.122-15.B.bin
2 26009164 Mar 31 2009 06:55:32 c7200-is-mz.124-18e.bin
21823488 bytes available (42401792 bytes used)
5. verify /md5 disk2:c7200-is-mz.124-18e.bin provides the correct checksum
gw-btvoice-sto2#sh version
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(15)B, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 31-Jan-03 01:13 by leccese
Image text-base: 0x60008954, data-base: 0x61BEC000
ROM: System Bootstrap, Version 12.2(8r)B, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-IS-M), Version 12.2(15)B, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
gw-btvoice-sto2 uptime is 12 hours, 56 minutes
System returned to ROM by reload at 20:28:35 CET-DST Sun Apr 5 2009
System restarted at 20:30:17 CET-DST Sun Apr 5 2009
System image file is "disk2:c7200-is-mz.122-15.B.bin"
cisco 7206VXR (NPE-G1) processor (revision A) with 245760K/16384K bytes of memory.
Processor board ID 23675723
SB-1 CPU at 700Mhz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.1
Last reset from watchdog reset
Bridging software.
X.25 software, Version 3.0.0.
3 FastEthernet/IEEE 802.3 interface(s)
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
gw-btvoice-sto2#sh file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
- - opaque rw null:
- - network rw tftp:
522232 513430 nvram rw nvram:
- - disk rw disk0:
- - disk rw disk1:
- - flash rw slot0: flash:
- - flash rw slot1:
* 64225280 21823488 disk rw disk2:
15990784 10852728 flash rw bootflash:
- - network rw rcp:
- - network rw pram:
- - network rw ftp:
gw-btvoice-sto2#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. image A4DAD420 526688 23 5137928 Jan 23 2000 02:33:13 c7200-kboot-mz.122-4.BW
10852728 bytes available (5138056 bytes used)
Correct Answer by rpfinneran about 8 years 3 months ago
Simon,
See attached. You need to put the new boot loader on flash, and it must be the first item in flash.
What I normally do is this. Format flash, then put first the boot loader for the new IOS. Then put the new IOS on flash. Next, on disk2, put first the boot loader for the old IOS. Then, put the old IOS. Finally, set your boot statements. This will provide a lot of redundancy. Try it out, try messing up certain parts (i.e. the new boot loader, or the new IOS). You will find that in the worst case, you end up on the old IOS.
Overall Rating: 4 (2 ratings)
Giuseppe Larosa Mon, 04/06/2009 - 00:50
  • Hall of Fame,
    Founding Member
Hello Simon,
you may need to load a newer boot loader code in the bootflash to be able to load the new image.
You see that you hace a 12.2(4) boot loader in bootflash c7200-kboot-mz.122-4.BW
try to copy in bootflash the appropriate boot loader for the new image and to set the boot loader image
Hope to help
Giuseppe
simonvyrdal Mon, 04/06/2009 - 01:05
Hello Giuseppe
I will try your suggestion tonight. I keep you informed. thanks simon
simonvyrdal Tue, 04/07/2009 - 00:30
I tried your suggestion with no success.
I copied c7200-kboot-mz.124-18e.bin into the bootflash. This was the situation when I reloaded
BOOTLDR variable = bootflash:c7200-kboot-mz.124-18e.bin
Untill now I reloaded from remote but decided to reload from the console. One of the first thing displayed on the console is
string is disk2:c7200-is-mz.122-15.B.bin
I don't know where this string is set but this must be the reason why the boot cmd's have no impact. Here is the output from the reload
gw-btvoice-sto2#reload
Proceed with reload? [confirm]
Copyright (c) 2002 by cisco Systems, Inc.
C7200 platform with 262144 Kbytes of main memory
Self decompressing the image : #########################################################################################
######################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Bridging software.
regards
simon
Leo Laohoo Tue, 04/07/2009 - 14:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Simon,
Remove Disk2:.
simonvyrdal Wed, 04/08/2009 - 00:06
Hi leolaohoo
Thanks for your answer. Sad to say that this was still no success.
Below you see a sh bootvar after coding boot system flash c7200-is-mz.124-18e.bin and wr mem.
Also you see a show version after reload.
Simon
2 26009164 Apr 07 2009 12:16:42 c7200-is-mz.124-18e.bin
boot bootldr bootflash:c7200-kboot-mz.124-18e.bin
BOOT variable = c7200-is-mz.124-18e.bin,1;
gw-btvoice-sto2 uptime is 2 minutes
System returned to ROM by reload at 09:52:53 CET-DST Wed Apr 8 2009
System restarted at 09:54:35 CET-DST Wed Apr 8 2009
Bridging software.
Giuseppe Larosa Wed, 04/08/2009 - 00:14
  • Hall of Fame,
    Founding Member
Hello Simon,
I would use the following command
or
boot system disk2:c7200-is-mz.124-18e.bin
With this kind of router you need to provide also the "drive" location of the file you want to load
Sorry I didn't think of this before
see for example on a C7200 of mine
sh run | inc boot system
boot system flash disk2:c7200p-advsecurityk9-mz.124-20.T.bin
boot system flash disk2:c7200p-advsecurityk9-mz.124-4.XD3.bin
this explains why it loads the old file: it is the first in flash
Hope to help
Giuseppe
simonvyrdal Wed, 04/08/2009 - 00:27
Hi Giuseppe
The first thing i tried (see the first post) was
In this case show bootvar displays
I have also tried
with (note the difference ,12 compared to ,1)
BOOT variable = disk2:c7200-is-mz.124-18e.bin,12;
In both case - the result is that the box boots on the first image on disk2:
Simon
Giuseppe Larosa Wed, 04/08/2009 - 00:42
  • Hall of Fame,
    Founding Member
Hello Simon,
I see.
I would suggest you the following:
upload with tftp the old ios image
delete it from disk2, squeeze
copy tftp flash the old image
now the first image should be the new one and try to reboot
Hope to help
Giuseppe
simonvyrdal Wed, 04/08/2009 - 22:13
Hi Giuseppe
Thanks a lot for your great assistance with solving this problem. In my answer to rpfinneran you can see I followed your suggestion as weel in making c7200-is-mz.124-18e.bin the first file on disk2.
Simon
Correct Answer
rpfinneran Wed, 04/08/2009 - 00:44
  • Bronze, 100 points or more
Simon,
simonvyrdal Wed, 04/08/2009 - 22:05
Hi rpfinneran
Many thanks for your help, the "Cisco 7201 Boot.pdf" was very helpfull. As you can see the ordering of the files suggest that the 7206 would come up on c7200-is-mz.124-18e.bin even without coding "boot system" cmd's. Anyway, thanks for your great help that solved my problem.
Simon
BOOT variable = disk2:c7200-is-mz.124-18e.bin,1;disk2:c7200-is-mz.122-15.B.bin,1;
BOOTLDR variable =
WARM_REBOOT variable does not exist
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image F34B50D2 804E9C 26 8146460 Apr 8 2009 16:14:39 +02:00 c7200-kboot-mz.124-18e.bin
2 .. image 9D00A02C DD69CC 27 6101680 Apr 8 2009 16:35:47 +02:00 c7200-kboot-mz.122-15.B.bin
1 26009164 Apr 8 2009 18:26:48 +02:00 c7200-is-mz.124-18e.bin
2 16371056 Apr 8 2009 18:32:58 +02:00 c7200-is-mz.122-15.B.bin
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(18e), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Mar-09 16:22 by prod_rel_team
gw-btvoice-sto2 uptime is 15 hours, 4 minutes
System returned to ROM by reload at 16:40:30 CET-DST Wed Apr 8 2009
System restarted at 16:43:19 CET-DST Wed Apr 8 2009
System image file is "disk2:c7200-is-mz.124-18e.bin"
Cisco 7206VXR (NPE-G1) processor (revision A) with 229376K/32768K bytes of memory.
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
