ASA5505- PAT
Answered Question
Apr 6th, 2009
We are replacing PIX 501 with ASA 5505. We are able to get the L2L VPN up but not the Internet access. When we try to add the NAT (Inside) x statement firewall gives warning message saying missing outside command. But If we add the Outside command to end of NAT statement we loose L2L vpns but Internet access works. Below is the config ..
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
Below are the Warning messeges
WARNING: Binding inside nat statement to outermost interface.
WARNING: Keyword "outside" is probably missing.
*** Output from config line 94, "nat (inside) 1 0.0.0.0 0...
We have tried 2 diffrent IOS
Cisco Adaptive Security Appliance Software Version 8.0(4) and Version 7.2.4.9
thanks in advance for the help.
Correct Answer by UCcomp2007 about 7 years 10 months ago
Unless you made an error when pasted config into this forum, you need to set your security-level for outside interface to 0 and inside security-level to 100. Your above message showed outside at 100 and inside at 0.
Overall Rating: 5 (2 ratings)
sykesemea Mon, 04/06/2009 - 01:03
Hello there,
Yes, We have configured this correctly and here is the config. I guess.. no issue with that as my Site to Site VPNs are working.
interface Vlan1
description Inside
nameif inside
security-level 0
ip address 172.x.x.x 255.255.255.0
interface Vlan2
description outside
nameif outside
security-level 100
ip address 195.x.x.x 255.255.255.248
interface Ethernet0/0
description outside
switchport access vlan 2
interface Ethernet0/1
description inside
speed 100
duplex full
sykesemea Mon, 04/06/2009 - 01:15
we have only 1 IP for this connnection and wont be able to try this.
sykesemea Mon, 04/06/2009 - 01:43
Hi Andrew,
Sorry for confusion, this is a xDSL link and we have only Static IP.
sykesemea Mon, 04/06/2009 - 02:06
We already have PIX501 working with is setup and i am not sure ASA not workin with the GLobal (Outside)1 Interace
Here is sh ver
Device Manager Version 6.1(3)
Compiled on Thu 07-Aug-08 20:53 by builders
System image file is "disk0:/asa804-k8.bin"
Config file at boot was "startup-config"
defraasa01 up 2 days 18 hours
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0 : address is 0024.97b1.e40a, irq 11
1: Ext: Ethernet0/0 : address is 0024.97b1.e402, irq 255
2: Ext: Ethernet0/1 : address is 0024.97b1.e403, irq 255
3: Ext: Ethernet0/2 : address is 0024.97b1.e404, irq 255
4: Ext: Ethernet0/3 : address is 0024.97b1.e405, irq 255
5: Ext: Ethernet0/4 : address is 0024.97b1.e406, irq 255
6: Ext: Ethernet0/5 : address is 0024.97b1.e407, irq 255
7: Ext: Ethernet0/6 : address is 0024.97b1.e408, irq 255
8: Ext: Ethernet0/7 : address is 0024.97b1.e409, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions : 2
This platform has a Base license.
sykesemea Mon, 04/06/2009 - 02:35
I dont have this ASA in production right now as we had this issue. During the testing , we have only 2 hosts in network. When Licenses get over, traselation wont happen?
FYI.. our currnt pix is also has only 10 host license and all working.
Does pix and ASA work diffrenlty in terms of licesnse?
We have orderd 50 hosts license for this and will be getting it soon.
Venky
Correct Answer
UCcomp2007 Mon, 04/06/2009 - 03:47
