LMS2.6 - Trouble with config backup
Apr 6th, 2009
Dear all,
I was advised that some of my devices are not backup-ed by LMS 2.6.
30 devices of the 137 seems to have the same problem.
yOU can see in attachemen the erros occured for a device config backup
Some have any idea ?
HE
glynncounty Mon, 04/06/2009 - 04:08
Looks to me that the credentials are not working. You may want to telnet into your devices and double check your snmp credentials etc... and make sure you check device and credentials under common services.
ilnaiduccna Mon, 04/06/2009 - 20:55
Hi All,
Instead of Telnet if the device have only SSH connection, then also it try to connect the device through telnet while taking backup.
Can you explain me about this.
Naidu.
