HSRP configuration
Apr 6th, 2009
I have two l3 switches A & B. A client router is connected to both these switches. No routing protocol will be used between the router & the two switches. ONly static routes are being used. The client router will have a static route for 172.16.x.x pointing towards the switches & static routes on both the switches towards the router.
However, since the client has asked me to run HSRP between the interfaces on the switches , i'm concerned abt the IP schema to be used. I would be greatly obliged if anybody could suggest on how to run HSRP between the interfaces in the switches connecting the router & also please suggest an IP schema that can be used....
Giuseppe Larosa Mon, 04/06/2009 - 01:43
  • Hall of Fame,
    Founding Member
Hello Solomon,
the HSRP VIP consumes one ip address of the same subnet in which the the two L3 switches and the router are connected.
example:
L3SW_1 : 10.10.10.2
L3Sw_2 : 10.10.10.3
HSRP_VIP: 10.10.10.1
router_lan: 10.10.10.4
you need to accomodate at least 4 hosts so the minimum size is 255.255.255.248 for the subnet
the router has to use the HSRP VIP as its ip next-hop to be effective
Hope to help
Giuseppe
daredevil24 Mon, 04/06/2009 - 02:24
thanks for the response .....but the router has two interfaces one each connecting to both the switches. Moreover i cannot configure two interfaces in the router from the same subnet right?.......PLease help
Jon Marshall Mon, 04/06/2009 - 02:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
deleted - posted twice.
Jon Marshall Mon, 04/06/2009 - 02:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Solomon
"but the router has two interfaces one each connecting to both the switches. Moreover i cannot configure two interfaces in the router from the same subnet right?."
Your'e right you can't. You could
1) bridge the 2 interfaces together on the client router. This would mean on link will be blocked by STP.
2) Use MHSRP on the switches so you can have 2 HSRP groups but this doesn't really help that much
3) Use routed links from the router to the switches. No HSRP but the client router would see 2 equal cost paths.
Personally i would go with 3.
Jon
