ipcc hosted intgeration problem
Apr 6th, 2009
Hello
I am setting up an ipcc hosted labs in my vmware system.The version of my icm is 7.2.Here is what i have done.
1 Configured 2 facilities a nam and a cicm.
2 I have installed Nam and Cicm as per the Hosted installation and configuration guide version 7 in the same vmware system as its just a lab environment.
Based on the configuration given you are suppose to select the Remote ICM under the system configuration Tab.Here when i select Remote ICM it gets changed back to custom gateway and i am not able to save it as remote icm.(Same for NAM as well as Cicm).Any idea how to turn this on.
My process in the cicm (incrpnic) shows online but shows 0 NAM.I have attached the snapshot.
AHMED Ali Mon, 08/31/2009 - 22:45
I'm facing the same problem in the LAB, could you please tell me if it is solved or not?
Ahmed Rizk
Riccardo Bua Mon, 08/31/2009 - 22:48
It seems you guys picked an application gateway node, meanwhile you should have a CIC process to provide the remote ICM id.
Riccardo
