04-06-2009 02:33 AM - edited 03-04-2019 04:15 AM
Hi Experts
I have 3750 Series swicth and 2950.
Problem: My Problenm is that i could communicate between same VLAN and even with diffrent Vlans after doing the following configuration.i have attached my configuration.
3750 Configuration:
1. I had configured the 3750 with VLAN 2,3,4,5,6 i have configured VLAN 6 is my Management Vlan.
2. I have enable the routing in 3750.
3. I have made enable the switch trunk encapsulate dot1q.
Switch 2950:
1. I have assigned diffrent port with diffrent Vlans.
Solved! Go to Solution.
04-06-2009 03:32 AM
Hi ,
Have you enabled routing on 3750 switch using command
Once again enable it using...
3750 config )# ip routing.
actually Gig interface of 2950 must allow command switchport trunk encapsulation dot1q ..
Can you send us show vlan output of 3750 and 2950 switch..
and "show interfaces trunk " output and show interface output after connecting laptops in vlan 2
Cheers :) MSK
04-06-2009 02:37 AM
Are you able to communicate with same vlan r diff vlan's or not..Your problem is not clear..can you explain it once again
Satish
04-06-2009 02:45 AM
1. I am not able to communicate from vlan 2 to Valn 3.
2. I am not able to communicate between Valn2 - vlan 2
04-06-2009 02:37 AM
Sorry, but youre not making sense. What is the problem?
04-06-2009 02:44 AM
Hi ,
As per my understanding there is no communication between same vlan and diff vlan..configured on 3750 switch.
1) create vlan database on the siwtches before craeting layer 3 vlans..
2) check the vlan database using command show vlan..
whatever vlans created on switch must be shown after executing command "show vlan " command..
Please check the below url for better idea...
How the switches are connected whoch ports are the uplink ports..
Can you send us show vlan output of both the switches..show trunk also
What is the uplink port on 2950 switch...
Cheers :)
MSK
04-06-2009 03:06 AM
1. How the switches are connected whoch ports are the uplink ports.
3750 is connected to 2950 using the following ports and they are the trunk porta
Fastethernet1/0/2-----giga0/1
presently i donthave any uplink to ISP
2. Can you send us show vlan output of both the switches..show trunk also.
I have attached the output of sh vlan and sh interface status.
3. Gigabit0/1
04-06-2009 03:12 AM
Hi ,
By seeing the output of show interfaces we can tell that no pc is conncted on any vlan...
You need to connect the laptop in respective ports so that vlan comesup..
Check the show vlan output...and how are you telling that there is no communication between vlan's..
and one more think is
int gig0/1
Must be configured on 2950 switch.
Take two laptops (give the ip's in vlan 2 range) and place them in Vlan 2 on 3750 and 2950 switch and check it works...
Please do the below thing..
3750 :
interface FastEthernet1/0/6
switchport access vlan 2
switchport mode access
Then
PC (192.168.2.251 ) - Int f1/0/6(3750 ) and
PC (192.168.2.252) - Int f0/2 (2950)
Try to ping 192.169.2.252 from 3750 switch..
Cheers :)MSK
04-06-2009 03:22 AM
I have done what you have asked me to do
which are as follows:
1.
Computer A:
IP: 192.168.2.2
Netmask:255.255.255.0
DEfault Gateway: 192.168.2.254
Computer B:
IP: 192.168.2.3
when i tryed tp Ping i could not ping From Computer A to B
2. My 2950 Switch is not allowing me to exicute (switchport trunk encapsulation dot1q)
i have exicuted switchport mode trunk insted of (switchport trunk encapsulation dot1q )
04-06-2009 03:32 AM
Hi ,
Cheers :) MSK
04-06-2009 03:44 AM
04-06-2009 03:58 AM
Hi ,
You have to use cross-over cable..and make sure that windows Firewall is disabled on PC's
Cheers :) MSK
04-06-2009 04:37 AM
1. I have connected 2950 and 3750 trunk ports with cross over cable.
2. I have diabled Firewall on both Computer A and B
WHERE AS I CAN PING ONLY FROM ONE END NOT FROM BOTH END.
Please help me
Kiran Kumar CH
04-06-2009 03:44 AM
I have to ask this ,when you ping are you sure you have the windows firewall "off" on both pc's ?
04-06-2009 04:04 AM
Grate!!!!!!!!!
when i stoped my Firewal on both PC
1. PC-A is pinging PC-B
2. Where as PC-B is not able to ping PB-A
please help me
04-06-2009 02:53 PM
Did you create a VTP domain?
Switch-3750 - VTP Server
Switch 2950 - VTP Client
