Multiple Default gateways on CSM
Apr 6th, 2009
  • Silver, 250 points or more
We have a CSM with different VLAN server and client configured in routed mode. We want insert more than one default gateways..i've read on the configuration guide that "the CSM will randomly select one of the gateways without your intervention or control"...but we don't want this happens..that is i want that the default gateway for VLAN client 1 is gateway1 and the default gateway for VLAN client2 is gateway 2 and so on...
I've read that this is possible with predictor forward..
Could you tell me how I can change this behaviour (that is randomly selection)?..
Thank you.
Best regards.
Massimiliano,
