1811 router - 2 WAN links
Apr 6th, 2009
i want to ask for this:
We bought 1811 router and want to make backup internet connections.
Connections are both using WAN ethernet ports. When primary connection will not work, router use backup line on another ethernet interface. When primary connection will be avaiable again, it switch back to primary connection.
Backup will based on ping-ing some internet address. When this ip adress will be unaviable then router switch to other line.
Can someone help me how to configure this scenario?
Thanks.
lubosbella Mon, 04/06/2009 - 06:49
Thank you Giuseppe, i will configure it tommorow. We will see.
Thank.
lubosbella Wed, 04/08/2009 - 05:27
here is my 1811 lab setup:
Current configuration : 3712 bytes
version 12.4
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp pool sdm-pool
import all
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
username install privilege 15 secret 5 $1$I0j9$e9IZaDtkAteV8nVX4Nhmo0
archive
log config
hidekeys
track 1 rtr 1 reachability
interface FastEthernet0
ip address 192.168.0.101 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 192.168.1.101 255.255.255.0
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip address 192.168.3.123 255.255.255.0
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.77 track 1
ip route 0.0.0.0 0.0.0.0 192.168.0.100 254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip sla 1
icmp-echo 192.168.0.103
timeout 100
frequency 2
ip sla schedule 1 life forever start-time now
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
So i have two internet connections 192.168.1.101 (primary, 192.168.0.101 (backup) and inside interface vlan1.
On interface vlan 1 will be server with address f.e.: 192.168.3.12 and 192.168.3.150 (iLo).
How should i forward/public ports 25,443 on router that this services will be avaible from to internet users? static translations, i think?
Thanks.
