inserting module in an active catalyst 6500
Apr 6th, 2009
I know you can hot swap modules but can you add one to an empty slot while the supervisor is active as long as the module is supported.
Leo Laohoo Mon, 04/06/2009 - 14:44
I agree with Mark. The 6500 network modules are hot-swappable. If no activity is observed in the first 5-15 seconds, make sure "power module " is enabled.
