Cannot mke offnet calls with Video Advantage running
Answered Question
Apr 6th, 2009
I have Video Advantage version 2.1.2. When I make an offnet call via an h323 gateway, I hear a fast busy and the called person hear the phone ring. When they answer the phone, they get dead air. When I close or disable Video Advantage, I have not problems with calls.
Correct Answer by Jaime Valencia about 7 years 9 months ago
When running Video Telephony Advantage (VTA), outbound calls fail from Cisco CallManager through H.323 gateways to PSTN. An invalid bearer capability IE field is indicated in the release_comp message
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K18460760
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
