BGP route reflector
Apr 6th, 2009
What's the role of using route reflector ?
Harold Ritter Mon, 04/06/2009 - 07:31
There is a rule in BGP that prevents a BGP peer to advertise an update to a iBGP peer if this same update has been received via iBGP. This rule is there to avoid routing loops inside a single AS. Before RFC1966, this restriction forced all bgp peers within the same AS to be fully meshed. RFC1966 defined the concept of route reflection to relax this restriction.
Please refer to RFC 1966 to learn more about how route reflection solves the routing loop issue.
Giuseppe Larosa Mon, 04/06/2009 - 13:15
Hello Omar,
the BGP route reflector feature allows to relax the need for a full mesh by providing some fields (BGP attributes indeed) that allow to detect a routing loop within a single AS:
the Originator-Id contains the BGP router-id of the router that originated an advertisement
the Cluster-list provides a list of all the "reflections" that an advertisement has experienced: it is made as a list of BGP router-ids of BGP route-reflectors (or of cluster-ids that have the same form of dotted decimal)
In this way a router in receiving different "copies" of the same advertisement can decide what info is more reliable.
And BGP route reflector servers can realize that there is no need to propagate an advertisement that has already been "reflected" by the twin reflector (the same cluster-id)
All starts from the fact that the AS path attribute is not modified within a single AS domain.
So somewhat similar mechanisms to trace the story of an advertisement inside an AS has been introduced with BGP route reflectors.
Hope to help
