Warning message
JamesLuther Mon, 04/06/2009 - 07:04
  • Silver, 250 points or more
The best way would be to enable netflow on your router and install a netflow collector.
Once netflow is enabled you can try using a few of the commands below to see traffic flows, however you'll see things much clearer with a proper netflow collector (there are a few free ones out there)
show ip cache flow
show ip cache verbose flow
John Blakley Mon, 04/06/2009 - 07:19
  • Purple, 4500 points or more
To add to James' response, if you don't have a collector, you can enable top-talkers on the router too.
ip flow-top-talkers
router(config-flow-top-talkers)# sort-by bytes
router(config-flow-top-talkers)# top 10
The above will configure the top 10 (and you can set lower or higher if you want).
To view:
router# sh ip flow top-talkers
HTH,
John
Joseph W. Doherty Mon, 04/06/2009 - 11:43
NB:
Release Modification
12.2(25)S
This command was introduced.
12.3(11)T
This feature was integrated into Cisco IOS Release 12.3(11)T.
12.2(27)SBC
This command was integrated into Cisco IOS Release 12.2(27)SBC.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
Usage Guidelines
Enabling NetFlow
You must enable NetFlow on at least one interface in the router; and configure NetFlow top talkers before you can use the show ip flow top-talkers command to display the traffic statistics for the unaggregated top flows in the network. NetFlow top talkers also requires that you configure the sort-by and top commands. Optionally, the match command can be configured to specify additional matching criteria.
bijithdmeethal Thu, 08/07/2014 - 22:45
Could someone explain this with example plz,  i mean with out put  to get better understanding
Tagir Temirgaliyev Fri, 08/08/2014 - 01:41
you can use not only netflow
also interface commands
ip accounting
and
ip nbar protocol-discovery
to see traffik use commands
sh ip accounting
sh ip bnar protocol-discovery
