04-06-2009 09:19 AM - edited 03-21-2019 01:01 AM
hi!
this is my first time here and am new to the UC500 so please do your your best to answer any stupid questions i might have.
Question 1 : I have 2 wireless SSID’s setup on the UC, I set them up using CCA but it seems I can only broadcast one. When I try to broadcast the other, I get an error from CCA. Can I broadcast more than 1 SSID?
04-06-2009 10:56 AM
Sam,
You can only broadcast one SSID using the embedded AP on the UC500.
Marcos
04-07-2009 06:16 AM
If you want to use more than 1 SSID you should use Cisco Wireless AP 521 series Access Point which is specially designed for SMB. For more information on configuring the SSIDs refer the document http://cisco.com/en/US/products/ps7320/products_white_paper09186a008096d82a.shtml#overview.
