Call Manager 6.1>User Management>End Uer
Apr 6th, 2009
Delete Selected or Add option is not there. Syncing it with AD using LDAP
Jaime Valencia Mon, 04/06/2009 - 12:00
you need to add users in AD, if you delete them from AD garbage collector will erase them from CUCM after 24 hours
java
if this helps, please rate
atiqmadani Mon, 04/06/2009 - 12:38
Is there a way to force AD garbage collector or deleting of the user
Jaime Valencia Mon, 04/06/2009 - 12:41
no
After the synchronization is completed, any accounts that were not set to active are permanently deleted from Unified CM when the garbage collection process runs. Garbage collection is a process that runs automatically at the fixed time of 3:15 AM, and it is not configurable. The deletion of Unified CM accounts that do not match LDAP directory accounts is necessary because Unified CM cannot manage accounts while synchronization is configured.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html
java
