George Thomas Mon, 04/06/2009 - 12:05
Thanks Buddy. But I am getting an error when trying to add a subscriber to a cluster. The Error is "Cannot communicate with publisher on UDP port 8500" . Any ideas?
Jaime Valencia Mon, 04/06/2009 - 12:11
there are some bugs:
CSCsi11535 : install to verify network connectivity early or separately
CSCsl95815 :reinstall sub with hostname change fails
CSCsk45350 : Network validation fails on Sub the first time but succeeds upon retry
make sure you already added the SUB to the PUB config. in some cases a simple reboot fixes this.
java
if this helps, please rate
George Thomas Mon, 04/06/2009 - 12:17
I have added the SUB in teh PUB config. Rebooted the PUB couple of times. Still going nowhere. What is the recommended MTU size? 1500? Do i have to change it on the PUB too?
George Thomas Mon, 04/06/2009 - 13:34
The servers were plugged into a HP switch. Replaced it with a LInksys and all is well. Bizarre...
martinbuffleo Mon, 11/02/2009 - 06:03
By adding to the Pub config did you just have to add the Sub as a new server (hostname and IP address) to the Web configuration?
I'm having the same issues with UDP 8500.
