Is it possible to change CER 2.0(3) hostname?
Rob Huffman Tue, 04/07/2009 - 04:36
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
From the CER 2.x Install Guide;
"Decide on a permanent hostname for the Cisco ER server before you install Cisco ER. Changing the hostname of a Cisco ER server after installation may cause problems."
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/2_0/english/administration/guide/e911inst.html
This caveat carries over to CER 7.x as well;
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/7_0/english/administration/guide/e911inst.html
Hope this helps!
Rob
Rob,
I was hoping those were idle threats from the Cisco documentation people who never tried to perform the task! :) And, I was hoping to hear from some renegade who defied those threats and lived to tell about it. I haven't brought my server into production yet; so I have an opportunity to test after making the change- and it seems that if CUCM's Linux OS architecture would allow it, then CER's Linux OS would, too. But, perhaps that is why I don't work for Cisco TAC or product development.
Thanks.
Rob Huffman Tue, 04/07/2009 - 04:52
  • Hall of Fame,
    Founding Member
Hey Michael,
Don't forget, this Hostname change is not supported in CCM Versions prior to CCM 6.1(2)(many early Linux versions :). I have dealt with some "rebels" who defied these threats and regret the fact they did. Given that this is not a production system, it may be worth a try;
Note: It is not supported to change the hostname on the Cisco CallManager server because the Structured Query Language (SQL) database does not support the hostname change. This is because SQL uses the server name for many of the tables related to Cisco CallManager and exchanges this information as such with the operating system. When SQL server is installed, it binds the database to both the machine and Cisco CallManager server names. If this is changed, the database does not replicate properly since the new Cisco CallManager or machine name is not updated correctly by SQL. **If a hostname change is inevitable, then the entire Cisco CallManager must be rebuilt.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094601.shtml
Prior to Cisco Unified Communications Manager Release 6.1(2), you cannot change the host name of either the publisher node or subscriber node after it is installed. If you must apply a new host name to a server, you can delete the server from Cisco Unified Communications Manager Administration (System > Server) and then reinstall the server with a new hostname. Also, be aware that a DRS backup that you take from a server with a particular hostname cannot be restored on a server (either a publisher or subscriber node) with a different hostname, even after you reinstall that node.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/ipchange/ipchg611.html
Changing the Hostname of Cisco Unified Communications Manager Servers
Starting with this release (6.1(2)), you can change the hostname of the first node or any subsequent nodes in the Cisco Unified Communications Manager cluster. You can only change the hostname of the first node from a subsequent node. The Cisco Unified Communications Operating System Administration user interface populates the hostname field on the Ethernet Configuration window and the Publisher Configuration window with the existing values. You can change the IP address or hostname of servers using the set network cluster publisher ip or set network cluster publisher hostname CLI commands.
Caution Resetting the hostname will cause your system to reboot and you may lose connectivity with the first node and the network. Before attempting to change the hostname of a Cisco Unified Communications Manager server, refer to the Changing the IP Address and Host Name for Cisco Unified Communications Manager Release 6.1(2).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp401012
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.html#wp185050
Hope this helps! Cheers!
Rob
