VOIP setup for the lab
Next year we are planning a VOIP migration for some of our in house users. We dont have any WAN connections and bandwidth between floors are gigabit.
What I am looking to do is buy a small setup for our lab this year so I can begin to learn about VOIP etc. So far I have researched and this is what I am considering buying.
- Cisco 2801-V/K9
- VIC2-2FX0 voice interface card
- 3560 24 port 10/100 POE standard image
- 5 7940G ip phones.
Is this a decent setup for the lab ?
Would it allow me to configure a basic voip setup and learn the fundamentals of configuring VOIP ?
Cheers
Dave
didyap Fri, 04/10/2009 - 07:15
  • Silver, 250 points or more
You'll have more luck with this question in the IP Telephony forum. I would say the setup looks pretty good though.
Justin Brenton Tue, 06/02/2009 - 15:44
You may also want to look into the UC500 Platform.
hth, please rate
Justin
Nicholas Matthews Tue, 06/02/2009 - 16:05
  • Red, 2250 points or more
Hi Dave,
You can probably get away with this for even less.
You could probably get something like a 1751-V with PVDM-256k and VIC-2FXS with the IP phones. You may need the power bricks in this scenario.
Alternatively,
CISCO2621XM with NM-2V with VIC-2FXS and the phones/bricks
But yes, your current setup will work. You would need to add something like a PVDM2-8, PVDM2-16, or PVDM2-32 for DSP resources, with the number depending on whether or not you want to play with transcoding/conferencing.
hth,
nick
paolo bevilacqua Wed, 06/10/2009 - 13:31
  • Hall of Fame,
    Founding Member
yes, you would be able to setup a very nice CCME system with all that. You could introduce some variations on the phone models to find out which one is better for you.
