UnityConnection 7.0(2) - Reinitiate Failed Locale Install
Apr 6th, 2009
Is there a way to re-initiate an upgrade (Locale file) that was canceled? I do not want to have to upload the file once again.
The 7.0(1)CLI guide suggests the following is available:
Usage Guidelines
To upgrade the system, follow these major steps:
1. Use the utils system upgrade list command to display a list of the .iso upgrade files that are
available on the local disk or remote server from which you plan to upgrade.
2. Use the utils system upgrade get command to get the upgrade file that you want to use.
3. Use the utils system upgrade start command to start upgrading from the upgrade file you got.
But these commands are not available in 7.0(2).
