AAA Authentication defaults to local enable password
Apr 6th, 2009
Copied configuration from 3560 to new 3560 defaults to the local enable password instead of using AAA/TACACS+ authentication.
Troubleshooting:
1. Verified configuration with known good 3560 switch.
2. Verified switch is able to see TACACS+ servers (show tacacs)
3. login authentication list applied to VTY lines.
4. Tried "login authentication default" on VTY lines
***Would enable secret password have any affect on VTY lines?***
Thank You,
Doug
Jagdeep Gambhir Mon, 04/06/2009 - 12:59
  • Red, 2250 points or more
It should let you in using enable secret.
~JG
douglas.mckee Mon, 04/06/2009 - 13:33
JG,
Would the "enable secret password" be the same for all switches authenticating through AAA/TACACS+?
Thank You,
Doug
