Client can't get IP from external DHCP via WiM
Answered Question
Apr 6th, 2009
WiSM 5.2.178.0
6509 12.2(33)SXH2a
WiSM is up, 1231 & 1131 APs joined, radios up, client associated but no IP address.
Virtual interface with vlan# & IP on the destination vlan.
WLAN with same vlan# as above.
Tried Open, PSK, WPA. Client cannot get an IP adress.
What did I miss???
Correct Answer by jeff.kish about 7 years 11 months ago
Do you have the virtual address set to 1.1.1.1?
Also, have you configured the DHCP server address on your VLAN interfaces? This is important because the controller basically uses an ip helper-address to properly forward DHCP requests.
If you have these configured, try using the internal DHCP server to make a test. Using the web GUI, go to Controller -> Internal DHCP Server. Configure a DHCP scope and enable it (don't worry, this is only used for wireless clients. It doesn't respond to DHCP requests on your network).
Now go back to Controller -> Interfaces and configure the DHCP server for the controller's management interface. See if your clients are able to get addresses from the internal scope.
Overall Rating: 3 (1 ratings)
jeff.kish Mon, 04/06/2009 - 13:40
  • Silver, 250 points or more
The Virtual interface should be configured with an unused externally-routed address. 99% of the time, this should be 1.1.1.1.
Other than that, make sure that your interfaces have the proper default gateways assigned. You can check this using the web GUI under Controller -> Interfaces.
Finally, check to make sure routing is working on these VLANs. Assign a switchport to your wireless VLAN and plug your client in. If you don't get an address through the wire, it's likely that your WiSM is configured correctly and you have a routing issue.
Jeff
mscherting Mon, 04/06/2009 - 14:41
My mistake. That should read Dynamic Interface.
Routing is done by the host 6509, gateway is correct.
Destination vlan is currently in use without issue by clients on autonomous APs.
Correct Answer
jeff.kish Tue, 04/07/2009 - 05:46
