Stacked 3750 lost Configuration
Apr 6th, 2009
I have 2 3750 Stacked and was working properly. Recently we had a power problem and power was lost to both switches simultaneously,when power was restored both switches lost their configuration, as if they are new or factory reset.I had to reconfigure again.
What would cause this to happen and what can be done to prevent this in the future.
Thank you
Basky Ramdeo
Leo Laohoo Mon, 04/06/2009 - 15:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
1. Someone didn't save the config.
2. Someone changed the config filename.
3. Someone configured the appliance to boot and use a different filename or location
4. Hardware failure.
baskyramdeo Tue, 04/07/2009 - 06:32
Thank you for your response leo.
Hmmm actually the configs was saved, i also had a backup on text which i used to get it up an running again quickly.No one supposed to have access to the switches to make any changes.Also they are still working after reconfiguration therefore not sure about the hardware failure. I do know it happened after power failure but no hardware part were changed afterwards.
Basky
