ACS SE with failed remote agent
Apr 6th, 2009
I have an ACS SE as the primary ACS, and ACS (Win32) as the backup ACS. When the remote agent on the ACS SE is off line the ACS SE denies login, how would I setup the ACS SE to not respond to requests if the ACS agent is offline
Jagdeep Gambhir Tue, 04/07/2009 - 10:07
ACS appliance and remote agent works independently. There is no way to make acs appliance not to respond, when RA is down.
ACS have internal users also, so if RA is down, internal users should be able to connect. So practically if is difficult to change this behavior.
What you can do here is to configure another remote agent as backup when first RA fails.
~JG
Do rate helpful posts
