ASA - Command to find which ports are open
Apr 6th, 2009
hey all, is there a command to quickly determine which ports are opened for a specific ip? it's a large config and the ip exists under different acl's and object groups. thanks, robert.
RicheeJJJ_2 Mon, 04/06/2009 - 22:40
sorry. No there really isn't. It's a series of commands.
show run | i
Will show you some of the instances of where that IP address. But if you see it listed as a name or a network-object then you're going to have to search for it by that name and that object group name as well.
Robert Ho Tue, 04/07/2009 - 01:13
yes, i am really familiar with | piping through the config. it does not help when the ip is part of an object-group.
