Checking RADIUS status
Apr 6th, 2009
Hi All,
I am doing an upgrade of RADIUS server, I would like if there is any way in which I can check out the RADIUS server is working fine in all autonomous AP and WLC. I want to do it proactively before any customer comes and complaints of the authentication failures..
Any help in the regard is appreciated
Johannes Luther Tue, 04/07/2009 - 01:04
on IOS APs, there is a test command.
(test aaa ...).
I'm not aware of a test command on the WLC software. But I guess you are not changing the IP, port or shared secret of the RADIUS server, right? You should be good with the IOS test commands.
nikhilcherian Tue, 04/07/2009 - 18:26
Can you guide me how to use the command. I would like to know the following things
Can I specify a RADIUS group ( I have got multiple RADIUS groups configured in my AP)
I see something called legacy and new-code in the last of the command, I couldn't get any help on those things
I tried with 1200 AP withVersion 12.3(7)JA2.
Leo Laohoo Tue, 04/07/2009 - 19:00
If you are using Autonmous IOS, then yes. You can configure RADIUS to your AP like you always do with other appliance.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
