How to troubleshoot C4k_L3HWFORWARDING Messages from Cat4500
Apr 6th, 2009
Hi there,
I got following messages from cat4500 in cyclic intervals
- WS-C4506 with Sup IV
- IOS: 12.2(46)SG
C4K_L3HWFORWARDING-3-
* MASKTABLECONSISTENCYCHECKFAILED
* FWDCAMCONSISTENCYCHECKFAILED
Searching thru cisco.com it is stated that TAC should be contacted.
Before doing that I want to ask the switching-experts how to further troubleshoot the problem and what is the real source of the problem.
Thanks for any feedback.
Lothar
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Tue, 04/07/2009 - 10:31
  • Hall of Fame,
    Founding Member
Hello Lothar,
these are consistency checks performed on the CEF tables.
The tests failed and this can be a sign that tables are corrupted.
There is a chance that some specific flows are not forwarded correctly by your device.
Or simply the tests can fail for some problem on the test execution caused by a bug.
I would schedule a maintanance window for reloading the device and then you can see if the messages disappear.
If they come back it is likely an hardware problem.
Hope to help
Giuseppe
lo.mueller Wed, 04/08/2009 - 01:54
Hi Giuseppe,
thanks for your feedback.
Do you know whether there are any test-commands available checking these consistency checks, or is this simply something going on behind the scenes?
Did you ever had this issues?
Lothar
Giuseppe Larosa Wed, 04/08/2009 - 03:38
  • Hall of Fame,
    Founding Member
Hello Lothar,
I haven't had the same issue but there had been threads in which the problem was a test reporting the failure of a linecard of type SIP and this was a false failure.
In your case being the CEF table used to forward traffic unless you see "holes" for some flows you should be fine
I tried to search for a bug unsuccessfully.
Hope to help
Giuseppe
