upgrading PIX 6.1(3) to 6.3(5)
Apr 7th, 2009
Dear all,
i need to upgrade software as in the subject.
i need the steps as well as configuartion file changes.
Upgrading from 6.1 to 6.3 wouldn't have any configuration changes.
1) Save the config to tftp server
pixfirewall# write net "ip add":pixconfig
2) Copy the bin file frm tftp to pix
pixfirewall#copy tftp flash
Address or name of remote host [127.0.0.1]? "IP add of tftp server"
Source file name [cdisk]? pix635.bin
3) reload the pix
pixfirewall#reload
if failover is configured on the box.
use #no failover
upgrade on pri, secondary unit
after upgrading on both units issue #failover
ibrahim_hassan Tue, 04/07/2009 - 04:04
i need to know how to convert the configuration file :
for example,
  conduit permit tcp host x.x.x.x eq www any
to be aplicable on 6.3(5)
