False-Car = False Carriers.
It is generally caused when the device on this port is disconnected/connected or power down/up.
It could also indicate something wrong with physical layer. You can try the following:
1. replace the cable
2. move to a diff switch port.
3. Check the NIC card and might be upgrade its driver.
