DND issue
Apr 7th, 2009
Hi all, I would like to provide users DND funcionality - just to reject incoming call, but if you adjust "call reject" under DND phone settings (or common phone profile), when you reject call you also activate DND function and other calls dont ring and there is also message on display that DND is activated.
Do somebody know how to provide just call rejecting with DND without activating of DND mode?
Thanks in advance.
TP
Overall Rating: 4.5 (2 ratings)
tprochazka Tue, 04/07/2009 - 06:56
Yes, thank you very much, but it hasnt solved my problem. You still just turn on the funcionality until you turn it off. There seems to be no one-shot possibility to reject the call. Or somebody know the way?
mhendren925 Tue, 04/07/2009 - 08:21
The closest thing I could think of would be iDivert. But what you're wanting sounds like a cross between iDivert and setting DND.
