ICM 7 - DB Lookup more than True or Flase?
Answered Question
I have a long..long list of DNs that I can put into a DN Lookup Node but this takes time and means a single change requires a resonable amount of re-work. I'd like to be able to put my DNs into a Table along with a DEPARTMENT code.
Ie:
DN DEPT
1001 Service
1002 Sales
And so use something like the DB Lookup or IF step to use Call.DialedNumber as the lookup value and return DEPT?
Is this possible with the builtin ICM DB Tools?
Dan
Correct Answer by villarrealed about 8 years 2 months ago
Dan,
I wouldn't add any additional tables to the SideA database. It would not affect syncronization, but during an upgrade, the table could be lost. Best case, I would point to a database external to the ICM system. Second best, I would create a new database on the logger or HDS and put that new table in the new database.
You would need to have the client create a new user with rights to the database & table. It would be best if the user had a non-expiring password. I haven't found any other way for this to work.
Overall Rating: 5 (2 ratings)
david.macias Tue, 04/07/2009 - 06:54
  • Blue, 1500 points or more
you could use a custom function for this, it could get very big and require some work on the front end. other than that, what you're looking for is something like a case statement in programming, which is not available through script editor.
david
villarrealed Tue, 04/07/2009 - 07:23
  • Bronze, 100 points or more
Dan,
Yes, the build in ICM db lookup can perform the database dip you want to perform. There are a couple of issues when using this step that I want to note. First, the step only allows you to look at one table, no joins are allowed. Secondly, the step will only filter based upon the primary key of the table. Looking at the example you provided, if you make the DN the primary key and only needed to perform a lookup on that field, it would work great for you. When setting this up, take a look at the Help in Configuration manager for the database lookup configuration. The configuration requires very specific references to the database and tables you are using. In addition, you will need to put the logon credentials in a registry key.
Hi villarrealed,
I've got the process working and it's working well. My only questions / concerns are:
1 - Can I add the new table (Called DNLookUP) into into the existing SideA database without causing any issues with replication syncronisation etc...
2 - The sa password has been changed and so I'll need to create a dedicated user ID to add to the Router Registry: Is their a smarter way (Creating IDs with non expiry are not liked by my client)
Dan
Correct Answer
villarrealed Tue, 04/14/2009 - 07:31
Dan,
