Did configuring Peap in ACS break my tacacs logins?
Answered Question
Apr 7th, 2009
So i just set up peap (certs and eap-tls) on ACS 4.0. However since then i cannot log into my routers anymore. I see the passed authentication on the ACS logs, but the router still tells me it's a failed authentication. I have a local username and password, but those all of the sudden stopped working too. If i reboot the ACS server i can then log into my routers while it's down. Once it comes back up, authentication fails again...ideas?
Correct Answer by Jagdeep Gambhir about 8 years 2 months ago
This is a know issue, Workaround is to disable the remote logging functionality altogether.
Bug has been raised for this issue,
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCeg40355
CSCeg40355 Bug Details
Authentication failures when remote logging fails.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Tue, 04/07/2009 - 09:57
  • Red, 2250 points or more
~JG
