IOS DHCP server
Apr 7th, 2009
My router is setup with two vlans on ethernet subinterfaces using dot1q. However, when my wireless clients try to get a dhcp address from the router, it hands out the address from the domain controller. Here are my router settings. Trunks have been verified. My guest wireless is on vlan 50
interface GigabitEthernet0/0.1
encapsulation dot1Q 60
ip address 10.3.5.132 255.255.255.224
ip hello-interval eigrp 10 1
ip hold-time eigrp 10 3
no snmp trap link-status
interface GigabitEthernet0/0.2
encapsulation dot1Q 50
ip address 192.168.5.1 255.255.255.0
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp pool DT-GUEST
network 192.168.5.0 255.255.255.0
dns-server 4.2.2.2
default-router 192.168.5.1
lease 7
John Blakley Tue, 04/07/2009 - 07:02
  • Purple, 4500 points or more
I don't know what kind of AP you have, but you'll need to make sure that the ssid that they connect to is associated to vlan 50. In a Cisco AP, it would look something like this:
dot11 ssid test
vlan 50
int do0
no ip address
ssid test
int do0.50
encap dot1q 50
no ip address
bridge-group 50
int fa0.50
encap dot1q 50
bridge-group 50
int bvi1
ip address 10.3.5.132.100 255.255.255.224
When the client associates to ssid test, it will map to vlan 50 and then pull the correct address. Otherwise, it will come over the default vlan, and it'll never hit the correct vlan.
HTH,
John
omar.elmohri Tue, 04/07/2009 - 07:05
In your case, both Router and Domain controller give a DHCP reply. and the DC is faster arriving to the client.
You would try to disable the DHCP server on the VLAN 50 or block the DHCP in the VLAN.
jgorman1977 Tue, 04/07/2009 - 07:42
One issue i noticed is that i had an ip helper statment on the same subnet as the guest wireless. My ACL's should take care of the DHCP requests to the DC.
Thank you!
omar.elmohri Tue, 04/07/2009 - 07:47
Please,
Can you send the command ? is to implemented on the VLAN 50 ?
This means that all DHCP is forwarded to the IP mentioned on the command. And you have to remove it, so no forwarding of DHCP request will be to DC.
Omar
Please rate if that help.
Leo Laohoo Tue, 04/07/2009 - 14:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can't you use "ip helper address" on your AP?
Is it a Cisco AP? Is it Autonomous or LWAP IOS?
jgorman1977 Thu, 04/09/2009 - 07:21
Didn't think about that, but got it working by putting the scope on our L3 switch.
omar.elmohri Sat, 04/11/2009 - 01:26
First, Have you tried to remove the ip-helper address on the Guest-VLAN.
Next, Put the DHCP scope on the L3 switch to give IPs to guest users.
Then, Give back a reply and I still following the progress with you.
Omar
