SRST translation patterns
Answered Question
Apr 7th, 2009
I have a 2811 MGCP gateway w/SRST at a remote site with a couple of issues during SRST fallback. All calls come in on a local PRI and I recieve 4 digits from the LEC
1) two DIDs for phones at the site utilize translation patterns on CUCM to route to their internal extensions and work fine during normal operation
DID 3041 TP to ext.2341
DID 3042 TP to ext.2342
During SRST fallback what is the best way to route these DIDs to the phones? Would it simply be translation patterns such as this:
voice translation-rule 3041
rule 1 /3041/ /2341/
voice translation-profile 3041
translate calling 3041
call-manager-fallback
translation-profile incoming 3041
2)an additional three DIDs also use translation patterns on CUCM to route across the WAN to our Contact Center (3rd party) server such as this:
DID 2333 TP 2300
DID 3533 TP 2300
DID 2173 TP 2300
when these DIDs hit my SRST router i want to hairpin them back out the PSTN (WAN is down) and dial the full 10 digit number to get to the Contact Center server. I already have a outbound dial peer for SRST so users can still 4 digit dial to other locations which works fine
dial-peer voice 12 pots
description ****SRST 4-digit dialing****
destination-pattern [2-3]...
port 0/0/0:23
forward-digits 10
prefix XXXXXX
are translation patterns the best way to go here or should I use something like num-exp?
Many thanks in advance!
Paul
Correct Answer by Ayodeji Okanlawon about 8 years 1 month ago
You could use the following config
voice translation-rule 1
rule 1 /^304./ /234./
rule2 /^2333/ /2300/
rule3 /^3533/ /2300/
rule 4/^2173/ /2300/
voice translation-profile IN-SRST
translate called 1
!Apply the xlation profile on your incoming pots port!
dial-peer voice xxxx pots
translation-profile incoming IN-SRST
incoming called-number .
direct-inward-dial
port 0/0/0:23
Overall Rating: 5 (1 ratings)
Correct Answer
Ayodeji Okanlawon Tue, 04/07/2009 - 11:30
  • Cisco Designated VIP,
    2017 IP Telephony
translate called 1
direct-inward-dial
port 0/0/0:23
pcaltagirone22 Tue, 04/07/2009 - 12:49
Many thanks for the response! I will put this on the VG at the remote site and test one night this week by dropping an ACL on the Metro-E port to force SRST.
Paul
pcaltagirone22 Thu, 04/09/2009 - 05:29
The TPs you provided worked like a champ - I did have to remove the ^ character - the VG didn't like that for some reason. Now if I can just get the telco to send RDNIS so voicemail works during SRST I'll be golden
Thanks again!!
