Fax Display support
Apr 7th, 2009
Is there any way the CUCM ver7 can prevent the display of code numbers like FAC or CMC on FAX?
CHRIS CHARLEBOIS Tue, 04/07/2009 - 12:06
I don't think CallManager has any control over that at all. I beleive that if that information is appear on the sent fax, it is because that information is captured by the sending fax and incorporated into the sent document. It would have to be a setting on the fax itself. FAC and CMC are not sent out to the PSTN and certainly wouldn't be carried by the PSTN in public call signaling, like ANI or Caller ID.
cegonzalez Wed, 04/08/2009 - 10:16
I mean on the FAX display like the FAC on the IP phone with Asterisk,is ther any CISCO documentation of it?
