DohPropTest password failing
Apr 7th, 2009
I am trying to use the usual formula for the dohproptest password (100-month)*(month+day), but it is faling.
Has enyone suffered this?
Ariel.
sopayne Tue, 04/07/2009 - 12:10
I just tried it on a test server and it accepted the values based on the server clock.
Have you confirmed that the input you are entering is accurate based on the server clock/calendar?
Also, you can access the data within dohproptest without having to enter the password, so that may be an option.
I hope this helps.
arielroza Tue, 04/07/2009 - 12:26
Sopayne,
Thanks for your reply.
Yes, I double checked the date/time. I also tried inverting the Day/month values in the formula, with no luck. I know that I can read the data without the pwd, but I need write access.
Ariel.
Christopher McAlpin Tue, 04/07/2009 - 12:47
Based on your last response, I am not sure you are formulating the password correctly.
100 minus the month = 96
Day plus month = 11
Password = 9611 for today.
