Port not working suddenly on C3560G Switch
Apr 7th, 2009
  • Blue, 1500 points or more
I have a C3560G-48PS running c3560-ipbase-mz.122-25.SEE2.bin and I had two ports just stop working, that I know of. I connected directly to the switchport with a phone and nothing. So I just shutdown the interface and saved and then did a no shutdown on the interface and then it started working again. I also had this happen to a 4506 switch as well with POE modules. I saw no errors on the interfaces, power was good, was not at the limit of power usage and the interface was not err-disabled. Also interfaces right next to them were working fine and they worked fine the day before. Any ideas on what may cause this?
lamav Tue, 04/07/2009 - 11:54
Hey, Muchael:
It looks like you really did your homework. I have to say that this has happened to me in the past and I was forced to bounce the port. I didnt give it too much importance unless I had to do it again.
You may have a hardware issue in its budding young stages. I would keep an eye on those ports.
I know I probably didn't drop any gold nuggets on you with this one.... :-)
Victor
burleyman Tue, 04/07/2009 - 11:58
I guess what has me a little baffeled is this happened on two different types of switches. The only simulatity was they are both POE. If you think of anything let me know.
Mike
Hieu Cao Tue, 04/07/2009 - 14:04
What messages do you see when you do "show log"?
burleyman Wed, 04/08/2009 - 07:42
Nothing shows in the Logs for this.
Mike
Leo Laohoo Tue, 04/07/2009 - 14:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You have a 3560G-48PS. This means that you can only provide 24 PoE ports. So if you plug in the 25th IP Phone port, it won't work.
Does this make sense to you?
Yes..I already checked that...plus I just move it down to another port and it works fine. I shutdown and no shut on the port nad it works fine. It is almost like the port is hung.
Mike
Leo Laohoo Wed, 04/08/2009 - 15:21
  • Hall of Fame,
    2017 LAN, Wireless
Has the switch been rebooted? Can you do "sh post"?
burleyman Thu, 04/09/2009 - 05:25
No need to reboot because the shut.....no shut....on the interface worked and the interface os now working good. What I want to find out is if someone has had this happen and if there maybe a bug with POE on the catalyst switches. This has happened on a Catalyst 4506 and the 3560 and issuing a shut no shut fixes it. Here is the Show post....
3560G#show post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Mike
Leo Laohoo Thu, 04/09/2009 - 18:15
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the post Mike.
I had a "similar" experience involving a 3750-E when the switch stoped ALL 48-ports from receiving power. Two other switches on the same stack were chugging away normally. It was a bug in the IOS and, get this, only occurs on brief one thousandth of a second on it's life ... basically, I had the unfortunately luck on getting it.
I reloaded the switch but didn't even thought about doing a shut/no shut. :P
Solved my problem though ... :)
