Using Unity as Company Greeting
Apr 7th, 2009
Hi;
anyone can guide on how to configure cisco Unity to act as a welocme company greeting then forward the call to the desire extension. I used to use this with IPCC Express sure, but we have limited number of servers and the only option is to use the Unity version 5 to act as AutoAttendant, is that possible?
Overall Rating: 4 (1 ratings)
uniccnp Wed, 04/08/2009 - 01:18
Hi Brad;
thanks for your reply and guide, it was very useful and as I understand from the link you provided is that I can setup a call handler and bypass the one-key dialing in order for the caller to be able to dial the full extension number, is that true?
Bradford Magnani Wed, 04/08/2009 - 06:13
  • Cisco Employee,
Yes,
By default "Allow callers to dial an extension during greeting" is checked under the Caller Input section of the call handler, which enables users to dial an extension.
Hope that helps,
Brad
jonathanwalton Sat, 04/25/2009 - 21:31
I just wanted to let you know there there is a great tool at http://www.ciscounitytools.com called Audio Text Manager, and it gives you a graphical way to manage your call handlers.
I have a few Unity VM trees, and it's saved me a bunch of time.
