Help understanding VRF
Answered Question
Apr 7th, 2009
Folks, in simple words, can I see VRF as a 'partition' in which multiple customers routing table can be handled separately? It is like creating multiple VPN's for various clients connecting to my service. Is that how you see it?
router bgp 98503
address-family ipv4 vrf MYTEST
no redistribute ospf 100 vrf MYTEST
redistribute ospf 100 vrf MYTEST match internal external 1 external 2
no aggregate-address 12.30.0.0 255.255.192.0 summary-only
exit
Correct Answer by lamav about 7 years 9 months ago
"Folks, in simple words, can I see VRF as a 'partition' in which multiple customers routing table can be handled separately? It is like creating multiple VPN's for various clients connecting to my service. Is that how you see it?"
Yes, that is a good way to look at it. It is especially useful to service providers who offer IP VPN services to multiple customers, who use the same service provider PE edge router. Wouldnt it suck for the SP to have to buy a new router to support each customer VPN.
It also allows the SP to carry network traffic for customers who use overlapping IP address ranges, which so common. Isolated VRF instances are created for each VPN, and the routes you see are specific to that VPN and have only local significance.
Victor
Overall Rating: 5 (1 ratings)
Correct Answer
lamav Tue, 04/07/2009 - 12:52
Victor
