Authentication configuration for L3 Switch
Apr 7th, 2009
There are 2 switches: one is Layer 3 switch and access Switch.
Need to add new Vlan (vlan200) that will be used to provide the users access to the server. And need to restrict access to vlan (vlan100) in the following manner:
1. User connecting to access Switch's port must be authenticated before they are given access to the network. Authentication is to be done via Radius server:
Radius Server host:
Radius Key: CISCO
Authentication should be implemented as close to the host device possible.
2. Devices on vlan100 are restricted to in the address of
Packets from devices in the address range of should be passed on vlan100
Packets from devices in any other address range should be dropped on vlan100
Filtering should be implemented as close to the server farm as possible
Config for the Access Switch
aaa new-model
radius-server host key CISCO
aaa authentication dot1x default group radius
aaa authentication network default group radius
dot1x system- authentication-control
int range fa0/1 - 20
switchport mode access
dot1x port-control auto
switchport access vlan 100
Config for the Layer 3 Switch
ip access-list extended checklist
permit ip
vlan access-map allow vlan100
match ip address checklist
action forward
or can i user it this way
access-list 10 permit
ip access-group 10 in
Leo Laohoo Tue, 04/07/2009 - 16:56
Errr ...
1. dot1x port-control auto is for NAC. Do you have a NAC server?
2. Where's your trunk?
3. What interface do you intend to apply "ip access-group 10 in"?
lmanavalan Tue, 04/07/2009 - 17:21
Yep, there is a RADIUS server installed.
Trunk is also configured between Layer 3 switch (gi0/48)and access switch (gi0/1).
And ip access-group 10 in on the Layer 3 switch (gi0/48)interface
