Route election
Apr 7th, 2009
3 sites, A,B,C connected with MPLS WAN
site A has network N1, site A CE use "network N1" under BGP to advertise it
Site B has static route, ip route N1 next hop xxxxx, SiteB CE BGP redistribute the static route
my question is
how Site C learn the the network N1, two routes?
how Site A reject/accept the route from siteB
Overall Rating: 4 (1 ratings)
Laurent Aubert Tue, 04/07/2009 - 17:32
  • Cisco Employee,
I assume you are in MPLS-VPN environment.
In this case:
1- For site C to learn N1, PE connected to site A and B needs to export N1 using route-target BGP extended community. PE connected to site C needs to import those routes. To be sure PE-C receives both routes, PE-A and PE-B should have a unique RD configured (in case there is a RR) and should both prefers their eBGP route.
2- It depends if you have the same BGP AS on site A and B and if the PEs are configured with the as-override feature. So we have the following scenarios:
- Different BGP AS: prefix accepted
- Same BGP AS with as-override: prefix accepted
- Same BGP AS without as-override: Prefix rejected.
Laurent.
study_voip Tue, 04/07/2009 - 17:37
Thanks for your reply
it is MPLS-VPN, same BGP AS for all sites.
so siteC CE will learn two routes, one is learned from site A via "network N1", one is learned from site B via "redistribute", which one will take preference?
for site A, since it already have route to Network N1, so if site A learned one another route via site B(redistribute), how site A to make routing decision?
thanks again
Laurent Aubert Wed, 04/08/2009 - 05:39
  • Cisco Employee,
Site C CE will not learn two routes but only the best one selected by Site C PE which will have the two routes.
Site C PE will apply the BGP route selection algorithm to make its choice:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
If PEs are configured to do as-override, Site A CE will accept the update originated from Site B but will prefer by default its local network (see link below)
Laurent.
Laurent Aubert Wed, 04/08/2009 - 05:40
  • Cisco Employee,
Laurent.
