Vlan trunk vs. vlan mode access
Apr 7th, 2009
I have this config in my network,
switchport trunk native vlan 16
switchport mode trunk
switchport voice vlan 201
is it the same as configuring
switchport mode access
switchport access vlan 16
What is the difference of this command if this is configured on a port wherein a computer is connected
tim1csolutions Tue, 04/07/2009 - 20:51
It's not the same.
In your second configuration you defined the port as an access port that is a member of VLAN 16. If you have other ports that are in this VLAN they all are essentially in the same broadcast domain - they can communicate with each other via layer 2. You would most likely be connecting a computer to this type of port.
In the first configuration the port is configured to be a trunk port with dot1q encapsulation. This port would be connected to another switch and frames would be tagged on egress. An example would be if switch 1 has ports in let's say VLAN 10 and 20 and switch 2 has ports in VLAN 10 and 20 you would trunk these VLANS over that port. The switch will tag the frame on egress so the switch on the other end of the trunk knows which VLAN the frame came from so the frame can be sent to the appropiate port(s) of the particular VLAN. the "switchport trunk native vlan" command tells the switch to send frames from that VLAN untagged.
rc.castillo Tue, 04/07/2009 - 21:19
Hi Tim,
Thanks for your answer.
But what i'm asking for is to what is the effect of configuring a port designed for PC with a trunk port. Can we say that it would be a cause of a broadcast storm in my lan if i have it configured on an access port
Leo Laohoo Tue, 04/07/2009 - 21:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
No. Configuring a trunk port-facing PC will not cause a broadcast storm.
If the port is connected to a PC, it is appropriate to configure the said port as an access port instead of a trunk port.
The only time I've configured a PC's port as a Trunk port is when I want to specify what VLAN is allowed to talk to the PC: Developers, Production, Funky, etc.
tim1csolutions Tue, 04/07/2009 - 21:29
I'm not sure I understand. Do you mean if you connect a PC to a trunk port?
rc.castillo Tue, 04/07/2009 - 21:35
HI Tim,
Yes i want to connect a PC to a trunk and specify it with a native vlan
tim1csolutions Tue, 04/07/2009 - 21:45
What would be the purpose of connecting a pc to a trunk port with a native vlan. Why not just connect it to an access port? The PC won't recognize tagged frames and it will drop them and you will just have excess broadcast traffic being sent out that port
rc.castillo Tue, 04/07/2009 - 22:01
Hi Tim,
So you mean that setting a port to trunk port can cause broadcast storm if you would put those pc to trunk ports
tim1csolutions Tue, 04/07/2009 - 22:05
yes if it is a large network and you were to configure multiple trunk ports and then connect a PC to each trunk port.
rc.castillo Tue, 04/07/2009 - 22:13
Hi Tim,
Thanks for the answer.
I'll try your suggestion, hope this will resolve our issue with regards to broadcast storm. One more thing, does broadcast storm contribute to the cpu usage of my core switch
tim1csolutions Tue, 04/07/2009 - 22:21
Yes. It can contribute to cpu usage. Common practice is to just connect the pc to an access port. If you are having issues with broadcast storms you can use the port level storm-control command.
rc.castillo Tue, 04/07/2009 - 22:25
Ok then. So what is the typical threshold you would set if you would apply the storm control on a per port basis. Would you only configure it on a trunk port or on the access port
glen.grant Wed, 04/08/2009 - 03:30
  • Purple, 4500 points or more
Servers and vmware installs are trunked all the time to a switch, not unusual anymore.
tim1csolutions Wed, 04/08/2009 - 10:52
Yes but not a pc/workstation just connecting to a trunk port for basic access.
