Rob Huffman Wed, 04/08/2009 - 04:41
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Lyle,
Yes, the CUCM 7.x Software Feature License is required. This type of license is required for any incremental step liek 5.x to 6.x, or 6.x to 7.x;
When you upgrade from an earlier release of Cisco Unified Communications Manager to Release 7.0(1), you must download and install a software feature license to activate the new features. For instructions about how to obtain and install a software feature license, see the "License File Upload" chapter in the Cisco Unified Communications Manager Administration Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp616664
Obtaining a Software Feature License
You must obtain a software feature license if you are upgrading from supported 5.x or 6.x releases of Cisco Unified Communications Manager. A software feature license activates features on your system for the specified license version. To use previous device license versions with this version of Cisco Unified Communications Manager, make sure that you obtain the software feature license for the Cisco Unified Communications Manager version that is running on your system.
Use this procedure to obtain a software feature license:
Procedure
Step 1 Navigate to the License Registration web tool at http://www.cisco.com/go/license.
Step 2 Enter the Product Authorization Key (PAK) that you received with your Cisco Unified Communications Manager upgrade.
Step 3 Click Submit.
Step 4 Follow the system prompts. You must enter the MAC address of the Ethernet 0 NIC of the first node of the Cisco Unified Communications Manager cluster. You must also enter a valid e-mail address.
The system sends the license file to you via e-mail by using the e-mail address that you provided. To view the contents of a software feature license, refer to "License File Contents" in the Cisco Unified Communications Manager System Guide.
Step 5 You must upload the software license file to the server with the matching MAC address that you provided in Step 4.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b02licfu.html#wp1067359
Hope this helps!
Rob
lyle.stevens Wed, 04/08/2009 - 05:14
I don't beleive I received a Product Authorization Key (PAK). What would the upgrade PAK's produce # look like because all I received is product #: UCSS-UCM-3-1K= which is a software subscription. Should the upgrade PAK's description say upgrade?
Rob Huffman Wed, 04/08/2009 - 05:31
  • Hall of Fame,
    Founding Member
Hi Lyle,
Great question! Yes, the PAK should reference the 6.x to 7.x upgrade and usually is shipped with the upgrade media. It sounds like you first need to complete the UCSS Activation and then order the CUCM Upgrade :) If this doesn't add up then I would fire off an email to;
[email protected]
and explain your situation :)
Cisco Unified Communications Software Subscription
Activation Instructions
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns165/ns737/net_brochure0900aecd805f0aa1.pdf
How to Obtain Major Upgrade Software License Files
When the Cisco Unified Communications Software Subscription is activated and you order the upgrades ordered through the upgrade tools, we will ship the upgrade as physical media; shipping takes approximately 5 to15 days. A new PAK will be packaged with this upgrade shipment. Please register this new PAK by visiting
to obtain your license file. We will send you the licenses for the upgrade software version ordered through the upgrade tool in an email message within 2 hours.
Cisco Unified Communications Software Subscription Overview
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns165/ns737/net_presentation0900aecd8063dc83.pdf
Hope this helps!
Rob
Rob Huffman Wed, 04/08/2009 - 06:06
  • Hall of Fame,
    Founding Member
Hi Lyle,
You are most welcome!
Cheers!
Rob
