Modular IOS and Regular IOS
Apr 7th, 2009
Hi All,
Can someone confirm if the modular ios is more stable than regular ios? Im using this Modular IOS in a 6509E and im getting high CPU,it shows on show process cpu that the ios-based is consuming more of the cpu process.
regrds,
reymon
Leo Laohoo Wed, 04/08/2009 - 01:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you post what version and feature set you're using? I have >50 Sup32 and about 12 Sup720 running modular IOS and I have yet to make any complaints.
Mhon Baul Wed, 04/08/2009 - 06:30
Hi leolaohoo ,
I'm using S72033-advipservicesk9-vz.122-33.SXI.bin and running VSS with FWSM. Before I use S72033-advipservicesk9-vz.122-33.SXH3.bin but this one doesnt support VSS with FWSM that's why I upgraded it to 122-33.SXI. Now I notice that upon converting to VSS, my CPU is always 40-50% and the ios-based consume about 30% and tcp.proc about 10%. What is the minimum cpu usage if you are running modular ios with VSS?
Joseph W. Doherty Wed, 04/08/2009 - 03:05
Recall while some releases of the non-modular IOS passed safe-harbor testing, same release of modular version did not. If true, and also considering that modular is "newer", would expect modular to be less stable. However, also believe current modular versions might be just a "good" as non-modular.
What release are you running?
Mhon Baul Wed, 04/08/2009 - 06:33
hi joseph,
im running s72033-advipservicesk9-vz.122-33.SXI.bin.
rgds,
reymon
Joseph W. Doherty Wed, 04/08/2009 - 17:06
Well that's certainly current. If you have software maintenance, something you might want to pursue with TAC.
