CUCM NIC duplex mismatch
Apr 7th, 2009
HI There,
We currently run a CUCM 7.0(2) cluster. I detected an error message on the syslog of the catalyst switch, where the two call managers are connected. The error says this,
"CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet5/17 (not half duplex), with syd-ccm-02 bond0 (half duplex)."
I have checked both the interface Gi5/17 and the nic settings in the call manager's etho and both are set to auto. mode. See below for the details,
Gi5/17 in catalyst switch (4507):
#show int gi5/17
GigabitEthernet5/17 is up, line protocol is up (connected)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
eth0 NIC: (call manager - MCS7825-h3)
admin:show network eth0 detail
Ethernet 0
DHCP : disabled Status : up
IP Address : IP Mask :
Link Detected: yes Mode : Auto enabled, Full, 1000MB/s
Duplicate IP : no
Queue Length : 1000 MTU : 1500
MAC Address :
RX stats:
bytes : 2365731208 packets : 16624908 errors : 0
dropped : 0 overrun : 0 mcast : 204461
TX stats:
bytes : 4293453743 packets : 35268789 errors : 0
dropped : 0 carrier : 0 colsns : 0
DNS
Primary : 10.0.100.252 Secondary : Not Configured
Options : timeout:5 attempts:2
Domain : 9msn.net
Gateway : 10.0.100.254 on Ethernet bond0
Can anyone please help me to pin point the mismatch issue?
Esteban
Anonymous (not verified) Wed, 04/15/2009 - 13:28
The "CDP-4-DUPLEX_MISMATCH: duplex mismatch " is logged when CDP discovered mismatching duplex configuration on neighboring interfaces.
1. Configure the interfaces so they are both running at the same duplex (full- or half-duplex).
2. Disable CDP
3. Upgrade the ios image to version 12.3 or later.
Alexander.Khlem... Wed, 06/03/2009 - 01:00
Hi Esteban,
We have exactly the same problem with CUCM 7.0(2a) servers connected to 3560G PoE-48 switches. Did you manage to find the solution to the problem?
Alex.
egua5261 Wed, 06/03/2009 - 23:47
Hi Alex,
Just need to restart the servers in order to sync up with the switch again; it seemed the issue was related to an older version of the IOS in our layer3 switch. Although the duplex/speed were set to auto on both the servers NICs and switchports there was a still a message coming up under the logs of the switch saying there was a duplex mismatch. The other way to fix is by hardcoding these paramaters on both ends.
Esteban
Alexander.Khlem... Thu, 06/04/2009 - 00:41
Hi Esteban,
We really prefer to keep them set to auto - the only way how we can use the 1Gb speed. Thanks a lot for the recommendations.
Alex.
