I have a question.
Apr 7th, 2009
Chassis is composed of below module.
Chassis = C4510R
Slot1. WS-X4516
Slot2. WS-X4516
Slot3. WS-X4148-RJ-45
Slot4. WS-X4148-RJ-45
Slot5. WS-X4148-RJ-45
Slot6. WS-X4148-RJ-45
Slot7. WS-X4148-RJ-45
Slot8. WS-X4148-RJ-45
Slot9. WS-X4148-RJ-45
When above case run, status of slot10 is "Not Support".
Command is used "show module"
I am wondering why slot10 isnot support.
I think that because Backplan but I don't know well.
Giuseppe Larosa Wed, 04/08/2009 - 00:07
Hello Kwangwon,
it can be a question of power budget.
What happens if you remove one of the linecards for example the one in slot 3 ?
Hope to help
Kwangwon Seok Wed, 04/08/2009 - 23:57
Hi~ Giuseppe
C4510R' capacity is 136Gbps and WS-X4516' swiching capacity is 96Gbps.
So isn't it possible ?
When I tested linecards it is good.
Giuseppe Larosa Thu, 04/09/2009 - 00:24
Hello Kwangwon,
I was meaning power consumption of modules not bandwidth or backplane issues
check with sh power
Hope to help
Giuseppe Larosa
agugger Thu, 04/09/2009 - 02:22
The 4516 has 96 1Gig Channel to support the line cards. 6 Are used per slot. Both 4516 borrow theirs uplinks from these 96 Channels. So the slot 10 can a maximum of 2 gig use. So only the 4502 line card can be used in this situation.
The 4516-10GE is different it has 96 Channels for the line cards plus the 10gig uplinks. But you have decide between the 4 1gig ports on the 4516-10GE sup exclusive or the slot 10.
agugger Thu, 04/09/2009 - 02:43
Hello Kwangwon,
The following note can you find at the “Release Note for the Catalyst 4500 Series Switch” see the link below:
When you use Supervisor Engine V in a Catalyst 4510R or 4510R-E chassis, slot 10 (FlexSlot) only supports the following linecards: the two-port GBIC (WS-X4302-GB) and the Access Gateway Module (WS-X4604-GWY). Supervisor Engine V-10GE has this same restriction when you configure its uplink select mode to all. Supervisor Engine V-10GE supports all Catalyst 4500 Series linecards in slot 10 when its uplink select mode is configured as tengigabitethernet or gigabitethernet. Supervisor Engine 6-E supports all Catalyst 4500 series linecards in slot 10.
