XML weirdness in Cisco ACE module
Apr 8th, 2009
I'm investigating the xml interface of a Cisco ACE module in a 6500
chassis and see something weird.
When I log in with SSH and do the following:
switch/contextA# show running-config interface
Generating configuration....
interface vlan 115
ip address 172.31.3.6 255.255.255.0
access-group input ALLOWALL
access-group output ALLOWALL
nat-pool 1 172.31.2.12 172.31.2.12 netmask 255.255.255.255 pat
no shutdown
switch/contextA# xml-show on
<xml_show_running_config>
<interface type='vlan' number='115'>
<ip_address address='172.31.3.6' netmask='255.255.255.0'/>
<access-group access-type='input' access-name='ALLOWALL'/>
<access-group output='ALLOWALL'/>
<nat-pool nat-id='1' mapped-ip-addr-start='172.31.2.12' mapped-ip-addr-end='172.31.2.12' netmask='255.255.255.255' nat-config-type='pat'/>
<shutdown sense='no'/>
</interface>
</xml_show_running_config>
Notice the difference between the access-group input/output in the xml
output. They differ a lot. Also the ACE will not accept the
configuration via XML that it outputted itself when I delete "interface vlan 115"
I get the following when trying to insert it via a HTTP POST:
<response_xml>
<command>
</interface>
</command>
<status code="105" text="XML_ERR_ATTR_INVALID">
<error_message>Error while processing Attribute: output</error_message>
</status>
</response_xml>
Relevant info:
Software
loader: Version 12.2[120]
system: Version A2(2.0) [build 3.0(0)A2(2.0)]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_2_0.bin
installed license: ACE-VIRT-050
Does anybody know why this is and how to fix this? It seems like a big bug to me.
With kind regards,
Tom van Leeuwen
