BFD - static routes
Apr 8th, 2009
Hi !
A static route should disappear from the RT as soon as the interface goes down.
As my device is connected via a SDH-equipment I am unable to recognize any failures within the SDH-network as the interface to the SDH-switch normally stays UP - static route will not be removed from RT
Is there a chance to use BFD to take down the interface in case BFD can not reach the other end anymore ?
thx
Hans
Giuseppe Larosa Wed, 04/08/2009 - 04:50
  • Hall of Fame,
    Founding Member
Hello Hans,
for your objective reliable static routing is enough:
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
you can track the state of the ip next-hop with a reachability test (icmp probe).
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1066247
Hope to help
Giuseppe
