WDS - Still authenticating at Radius after roaming
Apr 8th, 2009
Maybe someone can help me this: I installed a WLAN, consisting of three APs (1200), with WDS. The Clients can authenticate with EAP-TLS and valid certificates to a (free)radius-server. The APs authenticate with LEAP at the same radius and are shown as registered at the master WDS, but still every roam leeds to a new authentication at the radius. Did I miss something here? Do I need additional hardware for fast roaming here?
Overall Rating: 4 (1 ratings)
Johannes Luther Wed, 04/08/2009 - 04:03
What kind of encryption are you using?
This is from the wireless design guide from Cisco:
"Wireless LAN clients are always re-authenticated by the system in some way on a roam. This is always
necessary to protect against client spoofing. When wireless clients support Pair-wise Master Key (PMK)
caching as defined in the 802.11i and WPAv2 specifications, Cisco wireless LAN controllers support full,
secure roaming and re-keying without re-authenticating the client with the AAA server in the back-end. This
is true for both Layer 2 and Layer 3 intra- and inter-controller roaming. This feature is called Proactive Key
Caching (PKC). While no special client-side software is required to support roaming, PKC requires client-side
supplicant support. Please refer to the appropriate documentation for a detailed explanation of PKC."
bjoern.reese Wed, 04/08/2009 - 04:21
Hi, and thanks for the reply.
I use TKIP as the APs don't seem to support AES. (they're a bit older). So if I understand this right, I will need some special hard- and software on the clients to get this running? I thought everything is handled by the APs, so I won't have a chance to implement this, as long as we have the clients with mixed hardware, managed by the windows system?
bjoern.reese Wed, 04/08/2009 - 04:48
I'll try this, thank you very much so far for the tip. I'll try some newer APs and post here, if I find the correct solution and if I will ever get through all these acronyms. ;-)
