MGCP PRI config example
Apr 8th, 2009
I have 3 PRI's into gateways and I have been unable to get any of them to work under MGCP. The first 2 I gave up and reverted back to H323 but I am determined to get this last one working on MGCP.
Any config example would help.
The D channel comes up but it doesnt pass calls. csim's fail when attempting an outbound call....
Oh and qwest says the circuit shows in "lockout" on there side whenever I bring it up under mgcp control...
controller T1 3/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial3/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
dial-peer voice 101 pots
service mgcpapp
destination-pattern 6917404639515
port 3/0:23
forward-digits 10
Paolo Bevilacqua Wed, 04/08/2009 - 05:01
Why ?
Anonymous (not verified) Wed, 04/08/2009 - 06:27
well the first two we were in a major hurry and I didnt have time to play and make it work.
The 3rd we are in slightly less of a hurry AND this gateway has multiple tie lines in it so in order for me to route different partitions out particular trunks I need to have this one as an MGCP endpoint..
I suppose I could do it with dial-peers maybe.
Phone 82001000 in partition A to use trunk A
and phone 82002000 in partition B to use trunk B
Again with those trunks on the same physical gateway. If you have a clean way of doing it on h323 I am all ears.
Anonymous (not verified) Wed, 04/08/2009 - 06:49
Okay I could do that, but my local sales rep keeps beating on me to get everything on MGCP.
What is the benefit if you need to do all the work on the router for SRST anyway.
Paolo Bevilacqua Wed, 04/08/2009 - 06:53
"sales rep" ? As an engineer, you are supposed to tell him/her how things are properly done, not vice-versa.
For SRST, try "CME mode". Chances are you will like it and forget about MGCP once for all.
Vance Krier Thu, 04/09/2009 - 09:24
Well, I'm going to go against the steam here and disagree with Paulo..but definitely no disrespect intended.
I much prefer MGCP. I enjoy h323's stability, however in most situations, MGCP's ease of configuration makes it my preferred method. Especially when dealing with alot of gateways in an environment.
Following are some excerpts from my mgcp config script. Couple things that will get you:
1) Issue a show ccm and verify the router name is identical to the one you program in CCM. If there is a domain name programmed on the router, either remove it from the router or add it to the gateway in CCM, but they must match.
2) A dial-peer is not necessary for the PRI if there are no other configs...like SRST. Basically, you only need it if you have an overlapping config on the gateway and you need to make sure it hits the MGCP dial-peer first. Again, most common in SRST environments.
controller T1 3/0
framing esf
linecode b8zs
exit
exit
! Optional...See #2 above.
dial-peer voice 1000 pots
incoming called-number .
direct-inward-dial
service mgcpapp
port 3/0:23
exit
application
global
service alternate default
ccm-manager fallback-mgcp
ccm-manager redundant-host
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
mgcp
mgcp call-agent service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
Good luck!
Vance
